I have 2 in a silverstone ft02 and it says it can fit a max gfx card length 305, lightening is 305, however there is about 10-15mm room at the bottom of the gfx card to the case. R3 from memory is 295mm? So maaaaaay just fit, I can measure when I get home at 10pm if no one else helps
what heat? the hot air is dumped outside the case(nice in the winter if you're in a small room, save on heating bills ), xfire issues are a myth spouted by nvidia fanboys
