Will a new sound card possibly help with my problem?
3 Jun 2007
Essex
Hi Guys.
I have currently an Asus d2X sound card.
The basic problem I have is that I use an Avermedia live gamer to stream online but when I use the output on the sound card using 3.5mm jack into the input audio on the liver gamer card I get interference through my headphones...
Now someone said that getting a DAC may help prevent some of the interference but have just noticed the new batch of creative cards in the link below have a headphone amp built in... with buying an external dac or do basically the same thing as the inbuilt amp on the new creative card?
http://www.overclockers.co.uk/showp...ktdetailseite&emcs2=SC-088-CL&emcs3=SC-087-CL
Im hoping also the creative card does not need external power as I believe thats what is causing the interference on the asus card as its connected directly to the PSU also.
Are you getting interference when you don't use the Avermedia card at all, by connecting your headphones directly to the Xonar?
no interference only starts when im passing the audio from my sound card through the avermedia card and then out to headphones
My guess is, it's not the sound card that is the problem. If it were, I'm sure you'd hear it through headphones connected directly to it.
Possible that the Avermedia card is picking up interference and adding it to the sound. The fact that you also have this problem when using your onboard audio also suggests that it's the Avermedia card where the problem lies.
yeah you could well be right... might just wait and hope the xsplit guys sort their programme out so I can just use the card just to encode
thanks for your help guys
