Will a wireless bridge work for me?
Caporegime
8 Jan 2004
Rutland
I'm trying to find a better way to wire up my room.
Current setup is NTL cable coming into my lounge and connected to my Netgear router.
In the study I've got 2 pcs and a 360, currenly my PC connects via a wifi adaptor and everything else isn't connected.
I wondered if I could get either a cheap router and run it in bridge mode, or a proper wifi bridge and connect everything to that, and then set the bridge to connect to my main router.
Does that actually work? Any recommendations hardware wise?
As long as you don't have too many thick walls in the way a couple of wireless access points in bridging mode would do the trick yes. They have to support 'Bridging' mode though. I know some of the Buffalo kit does.
You could also look at the Homeplug adaptors.
Yeah I thought about homeplugs, but a router would be cheaper.
Do you know if you need matching hardware or should any combination work?
I hope you have better luck than me.
I just spent an afternoon trying to get two wireless routers to act like a wireless bridge and didn't get anywhere.
best bet, get 2x wrt54GL routers, put tomato firmware on them both, put first one straight into the cable, and put the wireless strength to max (this may be enough without the 2nd router!) if you need more, then set the other one to bridge mode
it's mega simple with those routers :)
tons of info & faq's here (probably won't need them)
http://www.linksysinfo.org/forums/forumdisplay.php?f=160
polarcloud.com is the homepage
