Will a XFX 650watt PSU fit in a BitFenix Prodigy Mini-ITX?
That case should take a normal ATX PSU no problem. You may want to consider a modular PSU though for easier cable management.
I just did a build in a little prodigy and used a power cool 750w and it was a good fit, you will be safe I think building it with the xfx one
Posted from Overclockers.co.uk App for Android
sorry to highjack, but is there a perfect PSU that fits into this case? needs to support 680 GTX so its going to need a bit of power behind it. Modular would be nice but not a must. A must is, that it fits comfortably inside the BitFenix Prodigy
The XFX 650 would be fine with a GTX 680.
I didn't use the XFX 650 in the Prodigy. I bought the Corsair Builder Series CX 500w Modular PSU and it works great. Very happy with it so far. I have heard some people having issues with these Builder Series PSU's. Working fine. If it does go I'll just RMA it:)
This case was a joy to build with. It only took me over a hour to build it, but boy was it fun.
I used a Corsair TX750m. Its semi modular and all the attached cables are used. It fits really well.
