Will a XFX Pro850w fit into a BitFenix Prodigy
No, it's 170mm. 160 is the limit, 150mm ideal.
Bifenix really should release a PSU adapter bracket for the prodigy.
That's a Lian Li PE01. I think you need to drill a couple of holes to make it work with the prodigy.
I pretty much forced in a Seasonic X-650 to the Prodigy. It is very tight and I have to say it is the warmest component in the case.
I am moving to a 550D next week anyway so I am not to bothered.
