Will All This Work?
6 Jun 2013
Here's the CPU loop I've put together, along with some accessories:
Will this all fit together and... work? The rad and fans pretty much are set in stone due to case, the rest is open to advice. The budget is stretched as it is so keeping costs down would be appreciated. If I got the block I wanted (Gold Supremacy) it would be way too much but this will do... :(
Yeah, generally looks OK, although I've counted that you need 8 fittings but you've only got 6 fittings listed
Personally I wouldn't bother with the hose cutter or the PSU Bridge (a sharp pair of scissors and a paper clip do a decent enough job)
I'll probably cut out the hose cutter (cut out? geddit?) but keep the bridger, idiot proof and cheap :)
I've got 2 90 degree fittings in there too.
Actually I've just realised the res won't fit...
Could someone help me find a smaller res that works with all the rest? I'm clueless with all the different reservoirs, just want one that's small and works. (And cheap of course)
If you want to stick with the EK pump have you considered the Pump/Reservoir combo, http://www.overclockers.co.uk/showproduct.php?prodid=WC-477-EK&groupid=962&catid=2133&subcat=1845.
If you want to keep the pump and reservoir seperate try the, EK Water Blocks EK-RES X3 110 Reservoir, or a bay reservoir.
