Will an 8800GTS fit into a Shuttle SB95P?
22BUK said:
I have scoured the net, but cannot find an answer as to whether an 8800GTS will fint into my Shuttle SB95P. Any ideas?
If this is a Shuttle SB95P V2 then,
Yes it will fit, the power supply should be OK for the job but you will find that the shuttle will overheat.
Solutions: Turn the 60mm fans on full, might be too loud for you.
Install a 120mm fan on the top.
