will an i7 720QM laptop processor be faster than a Q6600 pc processor?
17 Dec 2008
Okay so my computer right now has a q660 intel processor (2.4ghz),
Im thinking of getting a laptop to replace it, i mostly do 3d/compositing work so will the i7 be faster in terms of rendering?
A Q6600 runs natively at 2.4ghz on all cores, and is easily overclocked to 3ghz+, whilst a 720QM runs at 1.6ghz, and won't be overclockable at all, but can boost the speed of one core to 2.8ghz whilst under duress, so I'd say the Q6600 SHOULD be faster, but it would depend on how well the application supports multiple CPU's.
so the i7 can only boost the speed of ONE core? not all four?
Also the programmes that i will be using can make use of all cores
You also have IPC to consider though. I'm looking for a decent comparison, but my understanding of the new I7 mobile processors is that they are faster clock per clock than the older (kentsfield?) architecure the Q6600 uses. If the IPC is higher to a decent degree, and he uses programmes that by and large are NOT quad enabled, then he will likely find the I7 faster, as his q6600 is stock clocked. An 820 with higher clocks and cache even more so.
The 720 holds it own against a QX9300 laptop chip as it stands.
