Will Ax760i be enough wattage for crossfire r9290 widforce?
28 Nov 2013
I'm struggling to find any answer on this. Can someone please lead me in the right direction or be able to answer if I'll have enough juice.
cheers to anyone taking the time to apply
Regards
Craig
Not for crossfire unfortunately, which is ashame as it's a decent PSU you have. I'd be looking at a 850w PSU minimum.
You should be ok - what is the system spec?
i54970k - oc to 4ghz (haven't increased voltage yet)
maximus hero IV
H100i
8gb 1660 ram
samsung 840 pro 128
1 tb WD black
CD/RW drive
And I know im going to get a lot of flac for this but the keyboard mouse and headset I have are all Razer products.
I done a wattage calculator and it said I should have about 80-watts spare. Is that too close for comfort?
thanks
Thanks all for your replies.
looks like im getting a new PSU as well. Any suggestions would be greatly appreciated.
thanks
edit: bad grammar
I Weren't expecting this much help. you sir are a legend.
thanks
The XFX and the Antec are made by Seasonic.
Some are semi modular while others are fully modular and gold or bronze rated.
850W is what I use to recommend in the past for a pair of 290s in Crossfire with that sort of CPU and overclock, wattage calculators tend to be a bit "off".
I'm running a pair of XFX DD R9 290X's ( stock ) with a 4690k @ 4.2, on 1.2v, and have seen a peak pull of about 730w, I went with a 1000w just for headroom, and for the whole efficiency curve thing.
