Will fttc router work for adsl
5 Feb 2011
limerick
Hi there i need a new adsl router , since my vodafone huawey is pretty bad on wireless and in generel , now i was looking at the Asus RT-AC66U , but i am not sure a s i am really bad on networking if this will work on adsl , and if not i saw the Asus DSL-N55U , but ialso read a previos post say that should be better waith for 2nd generation tbh , now , small question is this out allready is it worth it to waith or the asus n55u will do just fine?
Thank you if you can help .
hi there thank you for the info , small question do what the difference if you know between annex a and annex b ,it seams there are different type , which one you have?
Annex B is for other counrtries, Annex A is the one you want.
Update the firmware -you can find it on the Asus website. Then do a hard reset (hold the reset button) to fully blank all the settings. Then setup the router.
Hey there thank you for the tip , i have order it and i will let you know how it goes , i found out then after your message about the a and the b , just look around for a wile it is just that when you are not to use to a field it is easy to ask when you see someone did it allready. i will let you know soon how i get a long, and for now thank you to both of you for the help .
Agree that this is a decent modem/router. Asus are updating the firmware regularly on this and it's getting better all the time. The next revision should add AiCloud to it (which the RT-AC66U does).
Andy
