Hello!
Since there's no sign of the 1080 ti or Vega card in sight at the moment, I've decided to push on and update my graphics card. I'm currently running an AMD 7950 which is holding up fairly well to be honest, however I'm looking at getting a 144hz monitor so I need a bit of a boost in power. I'm currently playing mostly BF1 and Overwatch.
I had a quick google but most threads I found were a good 6-7 months old and majority of the responses were people guessing. Monitor wise I was thinking of getting either:
BenQ XL2730 (27", 1440p, 144hz)
BenQ XL2430 (24", 1080p, 144hz)
My worry with getting the XL2730 is that the card won't be able to get a high enough fps on 1440p to get the benefit of the higher refresh rate. I normally set games to max settings and then bump down the Shadows + AA to get a decent fps, but I've no idea what to expect in this situation.
Would I be chancing my luck and better off going with the 24" 1080p instead to ensure I get the most out of the 144hz or do you think the card can handle it?
