Will I be able to play HDMI with the following?
12 Aug 2010
System Specification- Case: Antec 300 Gaming case - Black
- Power Supply: Corsair Extreme 600W
- CPU: AMD Phenom II X6 Six Core 1055T 95W Edition 2.80GHz overclocked to 3.80GHz
- Motherboard: Gigabyte GA-880GM-UD2H 880G
- Cooler: Titan Fenrir CPU Cooler
- RAM: Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Baracuda 7200.12 500GB 16MB Cache
- Graphics Card: Intergrated ATI Radeon HD 4250 with HDMI, DVI and VGA ports or a choice of latest DX11 cards.
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
- Cooling: 2x Xigmatek Crystal White LED Fans
Using a GTX 460 768M, as apposed to the Intergrated ATI Radeon HD 4250 with HDMI, DVI and VGA ports. Will this matter at all?
Monitor: Samsung SM2233RZ 22" 120Hz 3D Widescreen LCD Monitor - Black [LS22CMFKFV/EN]
- Screen Size: 22" Widescreen
- Resolution: 1680x1050
- Contrast Ratio: 20000:1
- Brightness: 300cd/m²
- Response Time: 5ms (2D) / 3ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x DVI-D
- VESA Compliant
- Dimensions: 516.8mm x 421.3mm x 208.7mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
Cheers,
Steve.
Does the graphics card have an HDMI out port? And does the monitor have an HDMI in port?
If the answer to both is yes, then you can use HDMI...
