i read you can get 120hz through this
https://www.overclockers.co.uk/showproduct.php?prodid=CB-021-SR&groupid=17&catid=2912
well then lets hope there is an adapter in the gfx card box if i am paying £500+ for it !!
Yeh, I think you'll find there are two hopes of getting an active adaptor with the Fury X, and one of 'ems called Bob!
dont understand that man, what you mean?
"You have two hopes, Bob Hope and No Hope, and Bob Hope is dead"
Really?!?!?!!?
That is bat **** crazy....
What is the reasoning behind get rid of DVI if you cant run high refresh out of the box without spending another 100 + bucks ?!?!1
Might be time to get a 290x ! !! !
you mean there wont be an adapter in the box? and i cant get 120hz over hdmi can i?
Really?!?!?!!?
guess what.. the 980ti even has a dvi DL !!! so that means i will need to buy this active adapter to run 120hz and if my psu isnt big enough then buy a bigger one and the card which is over £500 great
