I also failed two test in newcastle under lyme
dont worry you will get it third time, my two failures were totally my fault
These were both my faults too
Yes.
Maybe.
I don't know?
Although @OP sounds to me like you need to calm down and not be so cocky...speeding on your test is just plain stupid and as for you saying you would have probably got away with pulling out on somebody, i think you need to take a step back and remember that the examiner is the expert, they deemed that you were dangerous whilst performing your maneuver.
Basically my advice is - cool down a little bit, and make sure that you are definately ready for your test.
Don't forget to book your test for a Monday morning, I've read here that there are quotas so if they've passed too many during the day or the week they will fail you no matter how good you are. Also they play "test snooker" which means if you are driving a black learner car you are more likely to pass as the instructor will get 7 points over his mates, if you drive a red learner car then you are screwed as it's only worth 1 point.
With regards to the speeding on my first test, it genuinely was a mistake. I thought it was a 40 but it was a 30, I wasn't deliberately speeding I just made the mistake. I know the examiners the expert and at the end of the day his words final, but I thought I'd have been okay. But like you and I have said, his words final![]()
Fiar enough if it was a genuine mistake, sounds like you've probably learned from it though which is good.
On your next test you just need to make sure you don't take any risks, I was always taught that if you could walk across the road at a normal walking speed then you have room to pull out and if you are unsure at all don't make the maneuver, tbh it's better to get a minor for hesitation than it is to fail for dangerous driving.
When I come into power I'm going to bring in a 3 strikes and you're out rule. Don't pass by your 3rd test then you are banned from the roads, for life!
Mwahaha...
I don't know?
I passed 1st time. Sorry to hear about your life![]()
Keep at it, will pass eventually![]()
You will pass, once your fit to drive, which, from your comments, I don't think you are , yet.
