Yes.
And also an annoying extra monitor will appear in Windows if it does passthrough.
Thanks guys. Will the 5.1 sounds works too?
Does your amp / tv support HDMI ARC (Audio Return Channel)?
This allows the TV to "pass back" the audio via HDMI to the TV, so you could have your PC hooked up to the TV (with the TV ARC HDMI channel hooked up to the AMP) and all would work fine.
Fiddled around and the TV only passes back 2.0 stereo, so I can get sound using just one cable from the PC, but not 5.1
Nor does ARC allow you to use high resolution formats like DTS HD or 24bit sound.
Disappointing.
