Will i have enough power?
A2Z
A2Z
Permabanned
9 May 2005
Earth
Got a X1800XT 512MB coming soon to replace my 6600GT, will be joining my a8n-sli, winnie [email protected], 2gb corsair ram, audigy 2 zs, dvd-rw, and 3 (THREE) SATA Hard drives.
My PSU is an Akasa 400W, will this be enough???
also whats this rails thing about etc? is it important?
hp7909 said:
it says 372W on that...is my 400W PSU cutting it a bit tight?
Defo, my akasa 460w runs the rig in my sig perfectly
yes but you have an extra 60w :p
also on that site it says "The total Watts is important but the Total Amperage Available on the +12V Rail(s) is the most important, followed by the +5V amperage and then the +3.3V amperage. Because of the increased power consumption of the new high-power video cards the recommended minimum for +12V is 26A, for SLI 35A. "
on the side of my PSU it has +12v1 and under it 14A... :confused:
By 'coming soon' you mean you've already orderd it, right? If so, I guess its just a case of try-it and see if it works. If it does, or even if it doesn't, you should consider investing in a new+good PSU like the Tagan's :D
