wait for the DX 11 cards to come out at the end of the year it will be the ATi 5XXX series cards
get two of these for under £200 http://www.overclockers.co.uk/showproduct.php?prodid=GX-100-HT&groupid=701&catid=56&subcat=939
tbh ill keep the £200 wait for dx11 cards no point in wasting money.
up to you really![]()
Wouldnt touch 512 cards at 1080p.
Tbh wouldve kept the gtx 280, save up more and get a gtx285.
4870 is a downgrade and a 4890 is most likely on par with your gtx280.
May as well get a 4870X2 since its only going to cost you another £30 or so.
ive owned one and had problems i want a single gpu either the 4870 1gb or the 4890 1gb
I'd get the 4890 then otherwise if you get the 4870 it will be a downgrade. 10 - 15%your seriously going from a 280 to a 4890?![]()
Unless you are getting more for the 280 than you are buying the 4890 at i can't see how it is worth it.
