Will it become an issue?
2 Dec 2004
Under The Desk, Wales
Guys, i had to take out an itx mobo from my daughters pc case so that i could remove the io shroud to get to the cmos battery so that i could replace it.
To remove the io shroud i had to remove some screws on the rear of the mobo. While doing this i inadvertently slipped and one of the very tiny square 'things' soldered to the mobo came off completely!! There are numerous on the back of the mobo. All over the place...
Well, after assembling everything the pc works fine.
I thought the pc wouldnt work or at the very least have an issue but no.....
What do those 'things' do?
The back of the mobo has loads of these tiny square things soldered all over it....i knocked one off...
I cant post a pic.....
Its the rear of the mobo. It has loads of those tiny square things that are soldered to it. I broke one off....just curious if it will cause any long term issues?
X570 I AORUS PRO WIFI (Rev. 1.0) itx
If everything is working now, then probably not.
From what I can gather, they help to stabilise the power delivery to the CPU and some of them (especially on a higher-end board) may be overspec/redundant.
I see.....
There are literally loads on the rear of the board!!
Oh, you don't mean just on the socket?
The purpose would depend where it was.
No, not near the socket. Its on the rear of the board, away from the socket area. Like i said, they are all over the rear of the board..
Very possibly, it completely depends what it does. It’s a capacitor of some sort?
I once took apart a Mac mini and cleaned it up and in the process accidentally knocked a tiny chip off the motherboard. Initially it worked ok but after a couple days it killed itself off. It must have been something to do with voltage regulation or something but will never know…
Could you make a vague guess which area? It might be related to something on the board that you're not using.
Any good repair shop should be able to solder that back on and once component shouldn't be that expensive probably at most £50.
This bloke does repairs
I lost the bit...
Thread needs pics otherwise it’s guesswork tbh. Is there a part number or anything on the component which you have knocked off?
Cant take pic now as mobo back in the case.
No writing on it as it is very tiny. Its probably around 5mm. There are loads of the same on the back of the board.
Because you aren't really helping us help you, I'm not sure how you expect us to answer.
It would appear the only option you have is to use it and see what happens. In time, if there is a problem, it will manifest. Or it won't. Your guess is as good as ours.
Thing is, I can't take the mobo out to take a pic of the underside of it. I dont live with my daughter. But, I do appreciate everyone's advice.
