will it do 3ghz.??c2d
11 Dec 2005
the mighty hereford
ok youve probably seen a few threads like this before but do you belive this rig will do 3ghz. now i know it depends on the chip aswell as every does not clock the same. but do you beleive if i pick up a decent chip i can ht 3ghz with this setup. i will be updating ram in near future but i am getting 1gb for now.
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £84.99(£99.86) £84.99
GeIL 1GB (2x512MB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX21GB6400UDC) (£93.99) £79.99
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (£112.79) £95.99
Tuniq Tower 120 CPU Cooler (£34.06) £28.99
Sub Total : £289.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
Vat : £52.19
Total : £350.40
i dont think its a bad proce either for 350dead
yup, with an FSB of 450 ( which is easy on the DS3 ) , a 1:1 memory ratio ( multiplier = 2.00 ) and timings of 4-4-4-12 , which your memory should be able to do since its rated as CAS4 for 800 MHz ( it would be running at 900MHz with FSB=450)
that would get you 3.15GHz and with that cooler, should be fine. leave CPU voltage = 1.325 in bios if not one or 2 steps down.
have DDR voltage set to +0.3V in bios also.
Once thats proved stable start incrementing the FSB
