13 Feb 2007 at 18:35 #1 gwynn gwynn Associate Joined 5 Feb 2007 Posts 44 Hi to one all will my PC run Vista + Windows Aero AMD 64x2 Dual core Processor 3800+ 2.01 GHz 1.93 GB of RAM NVIDIA GeForue 6100/nforce 400 Chipset Thank you very much
13 Feb 2007 at 18:37 #2 Gas Panic! Gas Panic! Associate Joined 22 Jan 2006 Posts 924 Yes, definitely. The 2Gb is a definite bonus.
13 Feb 2007 at 18:51 #3 gwynn gwynn Associate OP Joined 5 Feb 2007 Posts 44 Rivey said: Yes, definitely. The 2Gb is a definite bonus. Click to expand... Thank you....Rivey the graphics are onboard so are you saying i don't need a graphics card
13 Feb 2007 at 19:01 #4 gwynn gwynn Associate OP Joined 5 Feb 2007 Posts 44 Just download Windows Vista Upgrade Advisor is said BASIC ONLY
13 Feb 2007 at 20:40 #5 decto decto Soldato Joined 24 Jan 2006 Posts 2,691 If you have a PCI-E slot or an AGP slot a cheap graphics card will give you aero, the rest of the PC is fine AD
13 Feb 2007 at 21:15 #6 gwynn gwynn Associate OP Joined 5 Feb 2007 Posts 44 decto said: If you have a PCI-E slot or an AGP slot a cheap graphics card will give you aero, the rest of the PC is fine AD Click to expand... thank you...decto i will have a look on OC
