Will it fit a 650D?
650D has 185mm CPU clearance, so will fit not problem
Without knowing what RAM you have I can't say if R1 Ultimate front fan will clear it. R1 Ultimate front fan can be raised to fit over 44mm tall RAM, which will leave you 146mm for 140mm fan to fit into.
Thanks chap!
I run Corsair XMS3 which apparently are 25mm tall with their heat sink (not measured it, mind!)
