will it fit advice ><
Mei
Mei
3 Jan 2012
im thinking of using a Noctua NH-C14 in a Silverstone PS07
i cant find any pics of systems with this same setup, maybe im not so pro with google but i cant ;_;
so its making me think its a bad idea or it just wont fit hehe
most likely be with a sniper m3 motherboard
any help be great thanks!
o and happy holidays!
If it helps the ps07 is the same (bar a few small differences) to the tj08-e, which I have. I don't know much about the c14 but I know the tj08-e can fit a d14.
it supports CPU coolers up 165mm high.
Happy holidays to you too
wow im actually surprised it fits the d14
but yeh its not the height im worried about, i think its 130mm tall with both fans, im worried there might be some overhang on the bottom, which normally would be the top but as its inverted etc
its a wide cooler for sure, matx mounting holes might push it too far down or something
ahhhs ><
if anyone can find any pics of a Noctua NH-C14 in a Silverstone PS07 be so awesome
nice find!
i was so wrong about the space at the bottom, i guess silverstone thought of that
its the space with the gfx card, the fans still need to clip on
and wont be able to use the hdd bays, tho not so fussed about that part
what cooler do you use on yours? im wondering if you have tried fitting a big cooler in it with removing the motherboard tray route
