Will it fit that is the ?
2 Nov 2003
Hi
I would like to buy a Creative X-Fi Titanium Fatal1ty Pro 7.1 pci express sound card for my asus motherboard but im not sure if it will fit in the only available pci express slot on my motherboard which just happens to be the very top one near to the heatsink.
Here is a picture of the pci express slot x4 at very top so you can see what i mean.
http://images.bit-tech.net/content_images/2008/12/asus-p6t-deluxe/9-8.jpg
and another view of it.
http://images.bit-tech.net/content_images/2008/12/asus-p6t-deluxe/5-8.jpg
do you think it would fit at a push or is it not going to happen.
Thanks paul
It does look like the heatsink is designed to allow a long card to used, belongs it's not higher then It should go in.
