Will it fit?
10 Jan 2008
Nottinghamshire
Hi all,
Just about to order a Antec Solo Quiet Mini Tower Case for a build I'm doing for my Dad. What I need to know is:
1) Will the ASUS P5K PRO Intel P35 Motherboard fit in it? The case says it supports Standard ATX = 30cm x 24cm but I've checked the board and its dimensions are 30.5cm x 21.8cm. Will the extra 0.5cm cause me problems?
2) The case also says it accommodates any ATX12V or ATX12V v2.0 PSU but the PSU I've chosen is Akasa Ultra Quiet 500W Paxpower Active PFC ATX2.2 PSU . This surely will fit and the only difference will be the power connection, i.e. , 24 pin instead of 20 pin?
Hope anyone can help. I want to order it tomorrow morning!
Thanks all,
RoEy
Thanks ShadowScotland.
I've found out the board will fit. I'm 99.9% sure the PSU will fit too. I plan to put this spec in it:
Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01991) £47.99(£56.39)
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB) £29.99 (£35.24)
Asus P5K Pro Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £72.99 (£85.76)
Akasa Ultra Quiet 500W Paxpower Active PFC ATX2.2 PSU - Black Nickel £44.99 (£52.86)
Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB) - Retail £99.99
(£117.49)
Antec Solo Quiet Mini Tower Case - No PSU £51.99 (£61.09)
PowerColor ATI Radeon HD 2400 PRO SCS3 SILENT 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £24.99 (£29.36)
Western Digital Caviar SE16 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) £37.99 (£44.64)
Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £14.99 (£17.61)
Thanks again mate,
RoEy
