Will it fit?
10 Jan 2008
Nottinghamshire
Hi all,
Just about to order a Antec Solo Quiet Mini Tower Case for a build I'm doing for my Dad. What I need to know is:
1) Will the ASUS P5K PRO Intel P35 Motherboard fit in it? The case says it supports Standard ATX = 30cm x 24cm but I've checked the board and its dimensions are 30.5cm x 21.8cm. Will the extra 0.5cm cause me problems?
2) The case also says it accommodates any ATX12V or ATX12V v2.0 PSU but the PSU I've chosen is Akasa Ultra Quiet 500W Paxpower Active PFC ATX2.2 PSU . This surely will fit and the only difference will be the power connection, i.e. , 24 pin instead of 20 pin?
Hope anyone can help. I want to order it tomorrow morning!
Thanks all,
RoEy
I've found out the board will fit. Just need to know about the PSU query now.
RoEy
