Will it Fit
28 Dec 2002
IOW
I will have shortly, a Lian-Li PC-60A Case + Asus Maximus Formula Intel X38 Motherboard, and was wondering if this Leadtek GeForce GTX 260 896MB GDDR3 card will fit in this case, before I purchase.
Hope somone can advise. first build!
Hi
I don't know whether that card will fit that case, but thought I would suggest you also check the 4870 unless you have some specific reason for not wanting to. It is shorter than the 260, but just as powerful, if not more so.
