Will it fit?
11 Jun 2006
Dominator airflow xtreme cooling system
Will that fit onto my ram
2gb geil black dragon 6400 800mhz 4-4-4-12
1gb sticks each in channel 1/3
Can you post a link to the product page for that specific memory? If the memory is not taller than Dominator / DHX heat sinks, then yes, it will fit as the fan clips to the memory retention tabs.
It's possible on both counts but, other factors such as the RAM itself, case airflow, MOBO etc are still going to play into it. Don't expect a dramatic increase from only the fan.
