Will it fit?
29 May 2009
Plymouth, United Kingdom
I have been thinking about downsizing to MicroATX and was wondering if my current PSU - BeQuiet Dark Power Pro P8 750w would fit in the Lian Li PC-V351B? Its quite a long PSU and a small case!
I had an OCZ 500 Mod Streme in the V351B and it only just fitted. I don't have it anymore so can't measure it, but it was a normal size, if the BeQuiet is longer than normal then you will have problems, the cables come out against the CD/DVD rack which is a solid wall of Aluminium.
The PSU is longer than my old Corsair VX550 so Im guessing it wont fit then. Ahh well, thanks.
sorry mine was a V354B so totally different -
Anyway, this pic of mine might help you decide.
