Will it fit ?
4 Sep 2012
Hi guys,
Thinking of treating myself to a http://www.overclockers.co.uk/showproduct.php?prodid=BU-115-OE&groupid=43&catid=2384&subcat=
and quite fancy getting a Fractal design define r4 midi case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-FD&groupid=2362&catid=1556&subcat=
Case can accommodate CPU coolers up to 170mm tall, as is listed in the product description and if i check the prolimatech website (
http://www.prolimatech.com/en/products/detail.asp?id=155&subid=409 ) it lists the cooler size as (H)158.7mm
Factoring in the motherboard/processor height anyone know for sure if i will come up against fitting issues ?
Any help is greatly appreciated
I would assume the 170mm quoted takes into account the motherboard thickness processor height and standoff's, so i would think your fine
