It most likely will fit, but add and image upload it to somewhere like photo bucket and add the link with the at the start and end in your post.[/QUOTE]
[quote="Fire_fly, post: 24024919"]Adding images to forum posts.
[url]http://forums.overclockers.co.uk/showpost.php?p=22789987&postcount=2[/url][/QUOTE]
thanks :D
Fixed.
And yes, it will. It's a standard drive sitting behind the case fascia.
Edit - And resized![]()
thank you, how did you do it ?
Found the link in your original post. You did it right but you linked the web page and not the .jpg full picture URL.
As for resize - Just downloaded it, resized in Photoshop and re-uploaded.
Please note - Check if it is an IDE or SATA connection drive.
It will physically fit in a new case but modern motherboards no longer have IDE headers, if it's an IDE drive you are stuffed and will need a SATA one![]()
That's SATA...does the other end plug into the optical drive?![]()
