Will it fit?
11 Sep 2012
Hi everyone,
I've got a bitfenix prodigy with a H100i in the top and wanted to know if the bitfenix recon will fit in the front without modding?
Anyone have this or know if it does fit?
I do not have an h100 myself to try but i've read that you can only install both if you push the h100 as far back as possible which will require you to drill new holes. As far as keeping it 100% stock i think you are out of luck..
