- 22 Sep 2007
- Abingdon
Hi,
I have the following water cooling bits so that my 4870X2 wont sound like a 747 taking off anymore:
NexXxos PROIII Rev 2 RADIATOR
3 x Scythe 1200rpm FANS
XSPC Razor XSPC4870-X2 Acetal GPU BLOCK
XSPC Dual 5.25" BAY RESERVOIR WITH PUMP (750lph)
7/16" Tubing
1/2" barbs
Feser One cooling fluid
My question is this: Can I get away with adding my CPU into this loop? My current CPU runs at 60oc under load, and my 2 GPU's run hotter than the sun
I've got a feeling I should already know the answer to this but if I am mistaken and there is a chance I can get my CPU water cooled too then it would be great. A recommended CPU block would also be appreciated
7/16" Tubing
1/2" barbs
