- 26 Mar 2006
Well basically I bought the E6300 and the Asrock CoreDual VSTA MoBo and well can't get it working
Just been checking to see if they will work together and it says that the moBo has a "VIA® PT880 Ultra Chipset"and the E6300 says that "Only compatible with new Intel 965 and 975X socket 775 Motherboards (Older 975 boards are not compatible)"
Does this mean that they are not compatable? Seen as though the Motherboard is under the "Other 965 Chipsets". If thats the case what you suggest I do?
Here is the link to the Asrock Site Linky
