Will it work?
19 Sep 2007
First of all I'm not sure if this is in the right section (move as appropriate :D) and secondly I have an idea! (and yes it hurt :p) The "plan" is to build a HTPC to be able to play dvds store some photos and music. However I am looking to do this on a budget :) (student) I was looking to use possibly a duron/sempron/celeron roughly 1.4ghz find 512mb a 250gb hdd and I was wondering if a HD 2400 would work ok with this system or would it be throttled for quality if I eventually used it for hd content if not can anyone suggest a suitable gfx card for dvds? My plan was to mount this in something inconspicuous like an old style speaker or large vcr what do you think? any suggestions?
any help or suggestions greatly appreciated
Cheers
Aero
well it depends on what i can fix hehe but I would like to work as cheap as possible I do have a 250gb hdd and a dvd drive and some pc2100 ram knocking around and if not i can pinch some 3200(i think thats right) from my brothers pc :)
well here is "new" set up :)
wouldn't be throttled and is hd ready :D
