Will my old memory work with Ryzen
18 Jan 2009
TeamGroup Vulcan 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - White
Ordered for my 5820 years ago.
Or should i get some more plan to run a 2950x would like to save a bit for a new m2 drive.
ram is ram so yes it will work,
you may have problem with XMP and may have to just set speed manually, older quad channel ram have a strange way for setting the speed by bumping the FSB, that's way many x99 gen CPU's would be overclocked when setting XMP on the ram
I have only just decided to look at the 2950x after the intel 9900k pricing put me off. Should i quad channel on the 2950x ?
The bios should handle the timings well, even if manual settings are required for higher frequency, tighter timings, if you are so inclined.
