will my rig run NFS:MW ok?
Depending on what res you are playing in you will be fine.
Runs absolutley fine on my rig with only the occasional slowdown.
The game runs 90% maxed out with my 3000+ Winny, 1GB of Cheapo RAM, x800xt all at stock at 1280x960 with 4xAA/8xAF :)
that'll run perfectly fine!
i'm running 32bit 2400m @ 2400mhz with a 6800GT and 1GB ram...
and it runs maxed out at 1680x1050 with no slow down at all, perfectly smooth!
Ive got it running with a mix of high and mid settings at 1024* on:
2.2 ghz p4
g4ti4600
512 ram
Plays fine to me and looks good (though i may be loosing some features on graphics as i dont think my card supports dx9 features??)
it will run amazing, it ran fine on my 9800pro, 2400xp setup before (never below 30fps in 1024x768) though i had to turn them bright light reflection things off
