Will my speakers work on my new TV?
6 Jan 2008
Hi Guys
I have recentley brought a Samsung HDTV and i wanted to know if my Creative 2.1 system will work on my new tv as the standard speakers are not very loud. At the mo i would connect it to my pc via a green audio cable so would i do the same and connect it through the headphone port on my TV?
Thx
That should work fine.
You may also have the standard phono red and white connectors on the rear of the TV, if you have a phono to 3.5mm adapter with the speakers, you may be able to use those connectors.
