- 13 Sep 2008
Hi all, (first thread: be nice)
I drive a Mk1 1.8 Focus. MOT is due in June and it might fail.. or it might pass.
Everything on the car is fine apart from one slight issue...
If i go above 40 mph in about 3rd/4th gear and drop the clutch or engage neutral the engine will die. It only happens when going from mid/high revs to idle quickly. If i allow the revs to drop slowly, or go from say 5th (so low revs) to idle, its fine.
I can live with it because i know exactly when its going to happen and know what to do to stop it happening, but its annoying. Most likely the idle valve has gone. I've already tried cleaning it and replacing stuff like crankcase ventilation hoses etc. but i think its coming down to either the idle valve has gone, or the evaporative emmisions control system has summit wrong with it.
Being a cheapskate student with a dissertation due shortly... I might not have the time or money to fix it myself, so question remains... is my stalling car likely to be picked up on an MOT or should i fix it first?
