I currently have 2 x Dell U2412M monitors connected to a single Asus R9280X-DC2T-3GD5 Graphics Card.
My motherboard is an Asus Z97 Sabertooth Mark S, which supposedly supports DisplayPort at 380x2160@60Hz, or HDMI with max. resolution of 2560 x 1600 @ 60Hz.
I really want to buy a 3rd monitor, Dell U2515H (2560x1440) and use it as the central monitor. Is there any reason I shouldn't be able to do this (I've never tried triple monitor setup before)?
I want to have the bigger monitor in the centre for movies/gaming - if it's possible, what would be the best way to connect them (i.e. which monitors to motherboard and which to graphics card)?
Specifications below:
Graphics Card Specs:
Motherboard Graphic Specs:
Dell U2412M connectivity:
Dell U2515H connectivity:
Resolution:
Interface:
DVI Max Resolution: 2560x1600
Interface:
DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D)
HDMI Output : Yes x 1 (via DVI to HDMI adaptor x 1 )
Display Port : Yes x 4 (Regular DP)
HDCP Support : Yes
HDCP Support : Yes
Integrated Graphics Processor- Intel® HD Graphics support
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DisplayPort with max. resolution 4096 x 2160 @ 24 Hz / 3840 x 2160 @ 60 Hz
Maximum shared memory of 512 MB
Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
DP 1.2 Multi-Stream Transport compliant, supports DP 1.2 monitor daisy chain up to 3 displays
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort(DP)
1 Video Graphics Array (VGA)
1 DisplayPort(DP)
2 HDMI(MHL) connector
1 Mini DisplayPort
1 DisplayPort (version 1.2)
1 DisplayPort out (MST)
1 Mini DisplayPort
