Will my water loop be able to cope?
22 Jul 2006
I am thinking of adding my 4850 into my watercooling loop.
Currently I have a 120.2 TFC Xchanger Rad & the xspc single bay res & pump cooling NB & 6300 @ 2.8.
Currently temps are fine, 32-34 idle, 42 - 44 load.
Just wondering if adding the 4850 into the loop will effect things much?
I do plan on upgrading the cpu at some point, but at the same time I will probabally change the pump also.
Cheers
It will probably raise the temps a bit, but shouldnt have too much of an impact. Your temps look pretty good as they are so i doubt a bit of an increase will have any effect of the performance.
You could probably do with a better pump though. The one in the single bay res isnt very powerful and may start struggling with 3 blocks in the loop. A Laing DDC or similar would be much better :)
Thanks for that, yeah i know I could do with a stronger pump, will see how it goes once the card is added into the loop. Hopefully temps wont go up too much!!
I've got a [email protected] and a GTX260 in one loop running off a carp swiftech 240 rad, under load cpu gets to 60° and GPU gets to 45° and the ambient temp is 34°
So you should be fine
I would ditch the drive bay reservoir, it has a low head/flow rate as it is and you're only gonna make it worse by adding more restriction into the loop :)
