Will Nest work with my heating system?
8 Jan 2003
Scotland
I have the following components in my heating system;
  • Ideal Logic Combi ESP1 35 Condensing Boiler
  • Honeywell Frost Protection L641B1004
  • Honeywell Outdoor Temperature Sensor SO10076
  • 2 x Danfoss TP5000 Thermostat
It's a dual zone system, with no hot water tank. I'm assuming the Nest Heatlink would replace the white Danfoss box at the bottom? And the two Nest thermostats will replace the two Danfoss units?
You would need two nests, each with a heatlink. You wouldn't replace the wiring centre with the heatlinks but rather connect them to it, schematically they replace the two thermostats (but are normally placed out the way near the wiring centre and the cable to the stat re-purposed for the SELV supply
So that white Danfoss box contains all the wiring and I would connect the Nest Heatlinks to that rather than opening the boiler? Both my thermostats/programmers are hard wired in, so I'm assuming/hoping swapping them out with the Nest thermostats would be fairly straightforward? I believe my boiler supports OpenTherm, are the connections for that likely to be in the Danfoss wiring box?
