will RavaTuner fan control mess with ati overdrive settings?
11 Nov 2005
I am have a X1800 XT and have it overclocked via CCC as I have had loads of hassle with ATI tool etc. So I have resorted to the path of least resistance. However I would like to use an app to control the fan speed which won't mess with the 3D clocks etc.
Hence i thought of Riva Tuner. Is this going to work or will it set my clocks to default 2D all the time?
Cheers.
Rivatuner will work...you can use that to OC the 3D speed of your card also....thats what I use for the same reasons as you stated.
