80 CUs seems to be a very popular prediction, regarding the spec of the top RDNA 2 GPU, on Youtube and other tech journalism websites.
Personally, I think it will have double the CU count of the PS5 (36), at the same clock rate of 2233Mhz or higher. That would give the RDNA 2 GPU a slightly higher TF count (20.5 TFlops) than the RTX 3070. I think the PS5 GPU has a TDP of 150w or lower, so doubling the CU's should keep the maximum TDP at 300w or lower.
The Xbox X series however, is thought to have a TDP of upto 200w.
There are some tech journalism websites that share this view, hinting at 72 CUs, with large GPU clock increases vs the previous generation.
Which do you think is the most likely?
