Will the big typhoon fit?
4 Sep 2005
London
Hi all
Just checking if a thermaltake big typhoon will fit in the following? :confused:
Antec Super Lanboy
ASRock DualSATA2
Seasonic S12
Those are the main bits of my concern.
Can anyone confirm it will fit?
Looking at the specs for the TTBT the space between the PSU and the centre of the socket has to be 6.1cm at the minimum.
Get a tape measure and measure 6cm either side of the centre of the socket. I reckon it will fit, but it might be tight...
Yep, it's about 7.2 from the center, should hopefully fit
