will the rtx 4080 fit in my case? please help before purchasing
23 May 2009
London
hi guys i want to get eiether an rtx 4080 founders edition or the msi ventus 3x and im just wondering can you guys help if these will fit in my case?
the case i have is the zalman s5 mid tower
the dimensions of the case is 398(D) X 212(W) X 465(H)mm
the maximum stated length gpu is 340mm..
the dimensions of the rtx 4080 founders edition is 304 x 147 x 61mm
and finally the msi rtx 4080 ventus 3x is 322 x 136 x 63mm
thank you guys much appreciated
zalman s5
total length for gpu 340mm
total hight for cpu cooler 163mm
For the length you are ok, but not for the height because 147mm height of gpu + 40mm for the 12VHPWR connector (187>163), except if you find custom 12VHPWR connector for your psu, or a 90 degree angle adapter.
so your saying it wouldnt fit purely because of the length of the 12VHPWR connector or?
i purchased the corsair official 12VHPWR from amazon will that help?
yes because it needs 40mm to make a bend
cables like this can have much tideer bend and it should fit
Before you buy, you need to check what type of cable your corsair psu is using.
well im using an rm750x psu from corsair
it dont come with the 12VHPWR connector.
so thats why i purchased one from amazon just incase.
and its exactly the cable you posted above.
so do you think theres a chance i can get it to all fit?
really appreciate the help
thanks so much for the help.
would you say the ventus would probs be an easier fit then the founders then?
