Will the Superflower Leadex Gold fit in my 600T?
27 Nov 2010
Have the Corsair 600T case, and just purchased the Superflower Leadex Gold 750W PSU. But I've just seen a couple people saying that it's a larger than normal PSU.
Just wanted to check if it will fit in my case?
Thanks.
If you go to the Corsair website and look at the specs for your case it will tell you the maximum PSU length it supports.
If you then go to Superflower's website and look at the PSU model it will give you the dimensions.
Then you can see if it will or not.
You also do not need two threads asking the same question.
Aaaarrrrrrggggghhhhh Stulid. I just typed a answer in his other thread with dimensions and links to pics, clicked on submit only to get a admin message. I have to do it all again now. :D:p:D
It will fit easily. It's only the length that's different, the width and height are the same as a standard size psu. The Superflower is 200mm long while most 750w psu's are in the 160-170mm range. There are a couple of pics in this review of your case showing a Corsair AX1200 installed which is the same size as the Superflower.
Yeah I did look at the specs before I posted the thread, but could only find a reference to the possible length of the cases PSU bit, nothing about width or height. Just wasn't sure if it was just the length that was big for the PSU or the width and height also, so just wanted to double check.
Thanks all.
Thanks all.
The Width and Height is 'Standard' across ATX power supplies (150mm x 86mm). You only need to check the length of the unit to determine whether it will fit or not.
Mine appears to be a slightly odd length (210mm) but it fitted in I had to remove the bracket thingy thats supposed to support the PSU backend somehow, its only fastened by the 4 case mounting screws. It sits on the bottom of my 600T so its supported ok, good thing too as it must weigh 4 or 5 kilograms. The case doesn't get moved much if ever so I figure I'm ok.
