Will the Thermalright Peerless Assassin 120 Fit in This Case?
17 Aug 2023
Istanbul-Turkiye
Hello Friends
I'm currently doing a system upgrade and trying to decide on a CPU cooler. Based on my online research and recommendations, I've decided to purchase the Thermalright Peerless Assassin 120 Black TL-C12B 120mm.
https://thermalright.com/product/peerless-assassin-120-black/
However, I'm trying to figure out if this rather large CPU cooler will fit in my case. My case is an Enermax ECA3052-BS Chakra Mid Tower...
https://www.newegg.com/enermax-atx-...axaJ1VVJm4gvVvUtDJTvvnD32Iexu2G0v3DFp96o0CwwJ
Do you think the Peerless Assassin will fit in my case, or should I look for alternatives with smaller heatsinks? For example...
https://www.hepsiburada.com/dark-fr...tucu-dkccx129-pm-HBC000002APIG?magaza=BUCHERO
https://www.hepsiburada.com/dark-fr...u-dkccx128-pm-HB00000WG6VX?magaza=Hepsiburada
https://www.hepsiburada.com/raijint...j-0p105245-pm-HB00000ZNQXN?magaza=MBTEKNOLOJI
https://www.hepsiburada.com/thermal...u-pm-HBC00008UJ9W7?magaza=BETA PLUS TEKNOLOJİ
Here are the other parts I already have:
https://www.sinerji.gen.tr/gigabyte-b850m-d3hp-8200mhz-oc-m2-am5-matx-anakart-p-54099
https://www.ucuzbudur.com/amd-ryzen-7-7800x3d-5-00-ghz-8-cekirdek-96mb-am5-islemci-tray
https://www.sinerji.gen.tr/patriot-...-6000mhz-cl30-ddr5-ram-pvv532g600c30k-p-51759
https://www-sapphiretech-com.transl...tr_sl=en&_x_tr_tl=tr&_x_tr_hl=tr&_x_tr_pto=tc
The graphics card isn't new. I'm going to transfer it from my old system to my new one, as I think it will last me a while longer.
I think it probably would fit, but you might be better off with a single tower cooler, e.g. a freezer 36 (height permitting).
Personally I would have replaced that case years ago. It was launched 20 years ago and uses the psu as a exhaust fan which is far from ideal. You don't have to spend a fortune to get a much better case that will take a decent cooler and have better airflow.
Sticking new hardware into an old case even with that side fan, it may overheat during gaming & that's not good for your hardware.
