If i were to upgrade from:
Xonar DS > Sony TA-D505* > Koss Pro DJ100
* A 1992 Hi-Fi Amplifier. I use it to bump up the low end, as my sound card can't quite chuck out enough power. The only problem is that the sound is also much more murky, and it requires cables going accross the room to the Hi-Fi.
to:
Xonar DS > Fiio E7 > Koss Pro DJ100
Will this little Fiio be enough to bump up the power for the low end? And without making the high ends sound a little 'murky' if it does so?
At a later date I would be getting an additional pair of headphones as well. Though i like these ones... They are half way between some lower end Grado's and some Sony xb500's.
to:
