will these all work together
16 Dec 2008
Antec 900 case
Q6600 @ 3.2/3.2ghz
N650SLI-DS4L motherboard
Geforce 8600gt (will be upgrading to ati 4850 or 9800 in future)
Zalman 9700
OCZ GameXStream 600w
Will these all be able to work together? and also will i have enough power from the psu to power it all?
i would get the corsair 650 its quiet and much better than the ocz psu
you will find the ocz has very short cables
the 900 is a good case - but surely there is something more imaginative on the market?
how about
http://www.overclockers.co.uk/showp...Lian Li PC-8A Aluminium Case - Silver (No PSU)
http://www.overclockers.co.uk/showp... II Aluminium Midi-Tower Case - Black (No PSU)
http://www.overclockers.co.uk/showp...in TJ04B Aluminium Tower Case - Black (No PSU)
http://www.overclockers.co.uk/showp...LUS Aluminium Midi-Tower Case - Black (No PSU)
all of those are much more stylish and probably better made
I have already purchase the antec 900, i love the look of it, plus i've only heard good comments about the cooling power.
so if i was to chance the psu to the corsair 650 as you suggested, would my system work all fine and fit? but also is there anything a bit cheaper that would be just as good?
buy cheap buy twice
do you really want your expensive components powered by a budget powersupply?
if it goes - chances are it will take everything else with it
rjkoneill is right, main thing i do when building a new rig is by a stable and reliable psu, i would rather spend more on a psu and get a slightly worse case that to spend more on a case with nothing inside that works :p
alright, i won't agrue with people who know what their doing, but overall should that all work together? as soon as i get a yes, will order psu and cpu cooler :)
That's a yes.
Everything will work together but as said above. You're better off with a decent PSU. I used to have a Colors-it PSU powering my rig until it starting to make some strange metallic noises. My confidence is much better with the Corsair. :)
p.s Great choice with the Antec 900, just watch out for the dust.
