Will these cards fit in my system?
30 Jul 2004
East Sussex, UK
Howzit guys,
I am on the look out for a new GFX card. At the moment I have an X800XT 256mb AGP in my Shuttle SN85 G4 V2. Fits just fine. Now the card I am after is the X1950Pro AGP single slot cooler. I was wondering if this would fit, also would a nVidia 7900GT fit or not?
Thanks guys!!
The 1950Pro will for in comfortably, but I dont have personal experience with the 7900GT. Try googling the length of the card
That's all I needed to know, if the X1950Pro fits, then I am happy. The 7900Gt was going to be a second choice if the X1950Pro didn't fit.
Thanks guys! :cool:
The only time you really need to worry about fitting your graphics card into a Shuttle is with the 8800 series, and even then most are fine.
The X1950 Pro is no longer than most other cards, probably not even bigger than your X800XT. :)
